TwinTurbo.NET: Nissan 300ZX forum - Re: no, i didnt use a lever, i used the old belt to loop around
Subject Re: no, i didnt use a lever, i used the old belt to loop around
Posted by wilkendw on June 17, 2006 at 4:34 PM
  This message has been viewed 91 times.
In Reply To no, i didnt use a lever, i used the old belt to loop around posted by NisVG 30 DE TT on June 17, 2006 at 04:27 PM
Message Do a compression check - if the compression is ok, your valves are probably fine. Like I said - never done what you did, so I don't know if that would bend a valve or not. If the transmission was in neutral maybe it would just push the piston down? If compression is bad on that side, probably need to replace a few valves. If so, let me know as I have a spare head sitting in garage.
